Old 02-24-2007, 07:27 AM
jams's Avatar
jams jams is offline
Cobra Make, Engine: B & B
Default Brake Pressure Multiplier
I posted this on the old server so I figured I would post it again.
Found this part in HotRod mag. Maybe this is the answer to brake issues. It must have a large piston pushing on a smaller one resulting in greater petal travel but greater fluid pressure.
I guess if you installed a master cyl. with a bigger piston you might achieve the same result?
http://www.ecihotrodbrakes.com/brake...ultiplier.html
Just enough knowledge to build a cobra and be dangerous...
You can observe a lot from just watching.
