Old 02-24-2007, 03:26 PM
Woodz428's Avatar
Woodz428 Woodz428 is offline
Cobra Make, Engine: Coupe,Blue w/white stripes SB; Roadster, Blue w/white stripes BB w/2-4s; SPF installer/Hot Rod-Custom Car builder
Originally Posted by woody2
In using the 28oz your motor will rev-up quicker. Good Luck!
PS not sure if the 5.0 crank can be used?
Since the weight has to be hung on the crankshaft, on either end, to balance...I can't see how that will change the ability to rev? The recip. parts are the same, and to balance out correctly the weight will have to be in the crank or added externally. It would seem regardless of which crank, that you will still be rotating the same "mass"
WDZ
