Old 02-25-2007, 05:30 AM
Default No pink thing
hey,little cobra Kristen I need a private address to send pictures of R&G 06 ERA has a tough time getting it's share on pictures and stories in mags. You are TOO CLASSY for that thong it. In Advertisement world sex sells, not in the cobra world, DUAL 4 BARREL HOLLEYS, 58mm WEBER CARBS, 12.5-1 COMPRESSION, 800HP, ALUMINIUM BLOCKS,and 110 octane gas. What a smell Here you are adopting another toy for the garage. Where do you find the time??? If you are not careful, there is going to be a fight in that garage for qualitity time. If you are looking for a part time mechanic, car washer, haul driver with a 2 car trailer, 3 square meals aday, I might fill out the application Buy the way, I talked to Morris ( not the cat ) and we need to up your frontend a little, not that, springs and shocks for the car. I am looking a the QA1 shocks with the dual control and 550 lbs springs for the front end. Also a bigger rear sway bar, I think it is 3/4" need to go to 7/8". You are lighter than me, 120 lbs is less. 500 lbs front springs may be all you will need also, but I think you have an iron block? 550 may be right on for you, I may need 600. Rick L. Ps I don't do an plumber work
