Old 02-25-2007, 06:20 AM
trularin's Avatar
trularin trularin is offline
Member of the north
Cobra Make, Engine: A Cobra
Socketed type like on GM trucks. The relay is plugged into a socket that has the wires mounted on crimps that lock in the base. Sounds like you have a version of this.
Studies show that this type of relay lasts the longest in high vibration and adverse conditions. Usually needs a hold down if in a fuse & relay cluster.
There are the industrial types that mount on a rail, trouble is those may fall out of the rail if you hit bumps.
Hope this helps.
