Old 02-25-2007, 12:24 PM
patrickt patrickt is offline
Originally Posted by MaSnaka
cold is at about 50psi and warmed up at temperature will drop to 25-30 while cruising.
You might not have as much of a problem as you think. What sort of pressure do you have at different RPMs when the engine is hot? What sort of pan/pump combination do you have? Solid or hydraulic lifters? Has the engine been rebuilt recently? Ever? What oil are you using? How hard do you push your engine?
