Thread: 427 side oiler
Old 02-27-2007, 04:17 PM
blykins blykins is offline
Easiest way to tell if it's a S/O is to look at the front of the engine. If you're facing it, look to the right of the timing cover. If there's a pipe plug there, then it's a S/O.
Also, it will have pipe plugs on the "humps" on the side of the block.
But the plug in the front is the easiest way....and you don't have to crawl underneath a car to check it.
