Old 02-27-2007, 11:28 PM
boxhead's Avatar
boxhead boxhead is offline
I do not have a Harrison, but my kit (Classic Revival) uses Ford rear and Jag front.
This is not an issue as the rim supplier should be able to provide the stud pattern you require.
And you will most likely be fitting different width front to rear rims so there is no point stressing about a spare that fits both front and rear.
I will be looking at getting a narrow multi fit 5 stud rim as a spare when I drive a long distance from out here at Alice.
Cruising in 5th
