Old 03-01-2007, 04:19 AM
Aussie Mike's Avatar
Aussie Mike Aussie Mike is offline
Holden Commodore stud pattern is 120mm PCD (Pitch Circle Diameter). This is basically a nearest metric whole number to the old Holden ie HQ and Chev stud pattern which is 4 3/4" PCD (120.65mm). The Ford pattern is 4 1/2" PCD (114.3mm) so it will fit on a smaller hub. I reckon the nissan rear hubs musn't be much larger than this diameter so that spacing the pattern out another 6mm might put the studs off the sides of the hub. This must be the issue Warwick is refering to.
With his price of $50 is that what he's asking per stud? I bought a set of new studs for the front of mine when I made the new hubs and the studs were about $15 each from memory. These were 1/2" studs the same as the Ford rears. There may be some other studs available from another car in the same thread pitch that work out a bit cheaper.
Mike Murphy
Melbourne Australia
