Old 03-01-2007, 06:06 AM
Plums Plums is offline
You should be able to unplug the IAC and set the throttle stop manually. Aim for a lowish idle of around 500 rpm (Auto's idle at 550). I have your idle set at 750, so the IAC will make up the difference.
It is best to have the throttle blade/s cracked a little bit for two reasons: a; the IAC doesn't have to work as hard, and b; it reduces the "off idle sensitivity" that comes from the instant rush of air as the throttle is opened.
