  #45 (permalink)
Old 03-04-2007, 12:05 PM
Ant Ant is offline
Default Air flow through hood scoop
Morris,
Great work very impressive as you have gone the extra mile to make sure the FE gets everything it needs! I will be doing a similar base shortly. I am 373 cuin running similar rpms, K&N tech advised me that the filter I have flows 923.16 CFM @ 1.5" (h20.)
I could run an X stream on top, or make up a foam insert, if I go to a 2" drop, that will give me 2 - 1/4" above the carb flange (MAX) to allow for an X stream, but I am not running a block under the carb, which helps to allow for the air/fuel to turn in the manifold, so I dont know what is more important say a compromise using a 1/4" to 1/2" four hole block and an X Stream on what I have, the X stream may give some benefit with a bit less gap!
Another issue I have tried to find out is " how minimal the gap above the carb needs to be, taking into consideration I can cut my air tubes down on my Pro 950 carb to a bit over half, doing a 45 angle on them, as they are quite long and straight at present, that might give me a little. All this is with a BIG 3.5" scoop on the hood!
A J. Newton
The 1960's rocked!
