Thread: fuel injection
Old 03-06-2007, 03:47 AM
Default O2 sensor mounting point
#136 The idea place is measure the size of your collector, say 3" and double it. this is where you mount the o2 sensor. If you don't have the room mount back as far as possible the mount on the angle is to keep moisture from laying on the O2 sensor. This in time will give you poor readings. Same thing with running Lead additives in your gas. A little is OK alot is not good. I have FI and run for 6 years a FAST system and it's great. I have my O2 on the inside of the exhaust between the body and sidepipe, about half way up as to keep it out of harms way. Rick L.
