I could be very easily talked into retro fitting the lamps to LED and including a flasher if I can get my mits on the right lamps to do it with.
I will have to dig a bit deeper I think.
Do you think LED side marker lamps would be bright enough?
Anyway I'm onto trying to come up with a handbrake arrangment now. I have discovered that since I'm using an auto that the MG style of handbrake will not be able to fit as the box is too wide. A desicion needs to be made as to where the handbrake lever will be positioned, and the jury is still deliberating.
Gav
Powered by Cu
