Old 03-09-2007, 05:40 PM
rokfor rokfor is offline
Cobra Make, Engine: FFR Roadster
You will need to center the steering wheel...then loosen the nut that is between the inner and outer tirerods....then turn the inner tierods until the wheels are straight. An alignment shop can do this a lot easier than it will be for you. It's not bad, you just have to adjust them lower the car until you get it right...a little time consuming.
Rob
GOD IS MY COBRAPILOT!!!
