Old 03-10-2007, 08:46 PM
FUNFER2's Avatar
FUNFER2 FUNFER2 is offline
I made two adjustable brackets that are bolted on the frame. A threaded rod goes through the brackets with nuts on both ends. I just take one nut loose, and the bracket spreads apart. Kind of like a screw jack. Then I can remove the radiator with the body & hood on. Make it a lot easier. If I can get a close enough photo, I'll post it.
Regards,
Kevin
