Old 03-12-2007, 04:35 PM
terry251's Avatar
terry251 terry251 is offline
Cobra Make, Engine: SPF Roadster, 418W
Pete, I'm not sure this will help, because I learned it on an ignition switch that mounted into the dash...but. There was a nut on the back of the ignition key module that loosened. I had to tighten it in order to take the tension off the key. Problem solved. I'm guessing it might be the same (along with the attendant locking mechanism in your more modern set up.)
Terry
