Old 03-13-2007, 06:35 PM
PaulProe's Avatar
PaulProe PaulProe is offline
Cobra Make, Engine: Hurricane - FE
Default Search Gates/Goodyear hose database
I am putting together a FE into a Hurricane chassis. Using a hybrid radiator, drivers side top inlet, drivers side lower outlet.
The top configuration was done this way to appear as the originals were built, using the L tube in the line.
The lower hose requires a number of bends to miss all the pieces. Current install is showing multiple pieces with tubes/hoses and about 6 clamps. I would like to come up with less pieces.
Is there a way to navigate one of the hose manufacturers system to find hoses that I could buy and possible eliminate some of the joints. Does any one of them offer a search by centerline and bend radius dimensions? Or does it take an "insider" to come up with this type info?
thanks
Paul
www.65shlb.com
www.prdcrrct.com
