Old 03-14-2007, 01:52 PM
Chaplin's Avatar
Chaplin Chaplin is offline
Cobra Make, Engine: Original ERA 427sc, Powered by Gessford
Uncovering the jets, as you've discovered, will make it not run at all. I guess technically it would be lean condition because the carb will be sucking the same amount of air, except that it won't be drawing any fuel because the jets are no longer covered by fuel and in effect are sucking air.
Replica is not a dirty word.
