Thread: Carpet advice
Old 03-14-2007, 02:47 PM
slow 427 slow 427 is offline
Cobra Make, Engine: CR 3205
Default Sound/ heat stuff
Originally Posted by cameron02
I'm carpeting mine at the moment too. I'm using a sound/heat deading underlay in on the trans tunnel (my exhaust goes through the tunnel). Basically its two layers of felt with a layer of bitumen in the middle. Then on the floor I'm just using normal felt underlay.
Cant tell you if it works well or not yet as I have not finished. Also consider getting your exhaust HPC coated if its heat your worried about. I can say that it seems to work really well.
Cameron what did you use and where did you get it ??
Thanks paul
