Old 03-14-2007, 07:48 PM
slow 427 slow 427 is offline
Cobra Make, Engine: CR 3205
Default Thanks
Originally Posted by Luke Gillett
Hi Slow 427,
Not sure what the black thing is but its something to do with the pollution control equipment.
In terms of plumbing, there are two small tubes (4 or 5mm) which need to go from the top of black thing to two of the nipples on the top of the fuel neck and two tubes go from the bottom of the black thing to the two nipples on the top of the fuel tank.
At the top of the fuel neck is also a third nipple for the connection to the charcoal canister.
Does this make sense?? I can probably sketch something up if it isn't.
Luke.....
Thanks Luke I see you have PBR brakes are they aluminium ?
And will they fit in 15 " wheels
Where did you get them and how much ??
Thanks again Paul
