Old 03-15-2007, 02:59 PM
richsd's Avatar
richsd richsd is offline
Cobra Make, Engine: 427 Cobra re-creation based on Kirkham aluminum body and chassis, Original 1965 Ford 427 Side Oiler and Ford Toploader transmission
Originally Posted by Beejay
Personally I do not consider a Cobra to be a Ford, but that is just my opinion. I am happy to build a hot rod that just happens to use the Cobra body. ..
Ben
There is no opinion here and nothing to debate on the points you make.
A Cobra is not a Ford as you say. It is a Shelby car with the body sourced from AC and it always had a Ford motor. This is a fact. Your opinion that a Cobra is not a Ford is correct but it is fact not opinion that Ford did not build the Cobra and it is fact that a Cobra used a Ford motor. Nothing to debate.
If you want to build "a hot rod that just happens to use the Cobra body" then you get a hot rod with a Cobra body.
