Old 03-21-2007, 07:48 AM
Tony Aprile's Avatar
Tony Aprile Tony Aprile is offline
Cobra Make, Engine: SPF #1358 Silver/Black stripes 466 2X4
Originally Posted by cwmcobra
Do you have any advice on how to avoid dumping coolant into the block valley when removing the manifold? I've obviously drained the radiator and quite a bit of coolant escaped from the water pump while the engine was tipped at different angles during removal. I'd like to keep the coolant out of the valley and the oil if possible.
Chuck
I have replaced mine several times over the past 4 years and as long as the radiator is drained and water level is lower then the thermostat housing you should be ok, Remove the T-stat housing first before removing the manifold and soak up as much the remaining coolant with paper towels or wet dry vac, there shouldn't be much.
Tony
