Old 03-22-2007, 02:58 PM
CWizard CWizard is offline
Cobra Make, Engine: SPF, 418 Stroker
Originally Posted by Morris
The Earls unit and the Mocal unit don't flow enough oil......
The Canton will handle a large volume of oil thru it......
It actually has a Big Rig Truck oil Thermostat inside of the housing....and works excellant.....
Morris - Could you explain the basis for your statements a bit? Like do you have flow rates for each of these units at the same pump outlet pressure? I'm not arguing with your position, just want to know more about how you got there.
Thanks,
Jerry
