  #28 (permalink)
Old 07-20-2001, 04:06 AM
SVMCOBRA SVMCOBRA is offline
Campy, what motor mounts did you end up using? I used the ford part number that was in the assembly manual. I ask this question because after installing my tremec the trans sits way to high (about 5") above the the crossmember. If I to have the wrong mounts then this would answer the question as to why it is so high. But if I drop the motor 2" then the driverside header will hit the frame. Also what transmission mount did you use?
Thanks, Ray
