Old 03-23-2007, 12:37 PM
cwmcobra's Avatar
cwmcobra cwmcobra is offline
Default Thanks Sal
Thanks for the detailed procedure. The end seals that came with the VR gaskets are cork with no self-sticking tape on one side. I also have cork gaskets from several Fel-Pro sets that do have the self-adhesion feature. I suppose I'd have to go to a Ford dealer for the rubber seals with the pegs. My block is drilled for the pegs.
Installing the intake manifold absolutely square is difficult on this engine because of the short coolant hose connection to the water pump. What I've done in the past is get the hose bibb installed into the hose with the intake totally off the gasket, then gently pivot the back of the manifold straight down until it contacts the gasket, then install and torque the bolts. I've had good luck with the three previous installs. All, when removed, were properly positioned. Of course, I did use a light coat of spray adhesive to hold the gaskets in place during assembly.
Chuck
