Thread: LS1 Accelerator
Old 03-24-2007, 12:59 AM
sideshow sideshow is offline
you canot interchange fly by wire stuff with non fly by wire
the ecus look the same but internally are different
looms are different
throttle bodies are different
you cannot run mechanical throttle on a fly by wire ecu system
as the ecu will shut down as soon as there is any probs with the fly by wire
im slowly organising afew hard to get parts for when doin these enignes
even the later 6lt engines make it hard to interchange stuff
only stuff u can change is the bare manifold and injectors
but then u have to get wiring modified
its best to just buy a compete set and stick with it
otherwise u will have headaches and need to chase up more parts
