Old 03-24-2007, 07:37 AM
Commander Commander is offline
Banned
what does the inside of the plenum look like
is it separated down the middle...two halves, or all open inside
if all open, then carbs too big, if divided, then only one primary set feeding half the engine...gets you into weber-think...one throttle body per cylinder instead of all venturi available for all cylinders like a 4v intake.
what'll wake that intake, and the engine it's attached to, up, is displacement. bore and stroke the bejebus out of it.
