Old 03-25-2007, 07:01 AM
Barry_R Barry_R is offline
The stroker motor - assuming the same heads and cam - will make more power everywhere below its power peak.
That power peak will be at a lower RPM by - this is a VERY CRUDE estimate - 10 RPM/cube. In other words adding the 3.98 stroke's 25 cubes will pull the peak point down by 250 RPM. Your heads will become a restriction sooner in the RPM range - but on an FE they are already likely to be a restriction...
