Old 03-27-2007, 12:36 PM
Jerry Clayton's Avatar
Jerry Clayton Jerry Clayton is offline
OK,, follow very carefully----
Remove the a-arm from the area---cut off the bolt so the nut can be moved outta the way--
Drill a 1/4 in hole thru the other side of the frame
Now mount a 1 1/2 or 2 inch hole saw and using the 1/4 in hole as the guide for the holesaw cut out a bigger hole(on the frame where the nut was welded)
Take a plate of steel and drill/holesaw and cut a circle of steel that matches the hole you sawed in the frame--drill the center out the size of the bolt you need to use
Weld a flanged nut on the circle
Weld the circle into the ho,e in the frame
Grind down the welds, paint, no evidence remains--
Now if you need this in 767 language, send me a pm and I'll give you my phone number
Jerry
