In my view your jag brakes will serve you well for sometime. As Phil says your ability to drive it faster around the track will be a greater challenge. Brake balance in my view is critical and I run standard jag front, ford rear and went to race pads and that improved performance dramatically. I also will be running cooling ducts to keep the cooler for Winton as brake upgrades a expensive and only worthwhile once you are driving to the cars braking limit which I still have a long way to go.
Leeroy
