Old 03-27-2007, 08:10 PM
pneall's Avatar
pneall pneall is offline
Rebel,
I think the issue is the side pipe design.....just not as good as a properly designed under car system with cross overs and equal length pipes....at least at part throttle applications.
However sidepipes do sound great.
I would have a look at the LS1 site to see what works but suspect 1 5/8 may be sufficient for a standard motor but larger may be better if you plan a cam.
Losing low down torque isnt a big deal as the Cobra is very light but you may notice it in 6th gear with the diff you are running.
Regards,
Phil
