Thread: tight engine
Old 03-31-2007, 08:59 AM
dynoroom's Avatar
dynoroom dynoroom is offline
1st check that you have crank thurst, sounds like you checked everything you should have "in" the motor, so is the flywheel on? Sometimes the bolts are too long and go through the crank and hit the rear main cap, look at that. Do you have rod side clearance? If it a Cleavlor does that mean you have an aluminum block? How did you check your bearing clearance, plasti-gauge, dial bore gauge or?
Michael LeFevers
Member of the Bonneville 200 MPH Club
1st Production Bodied Car Over 300 MPH
Kugel and LeFevers Pontiac Firebird
