  #39 (permalink)
Old 04-01-2007, 06:02 PM
Dinobyte's Avatar
Dinobyte Dinobyte is offline
Cobra Make, Engine: Backdraft #395 from Vintage Motorsports; Valley Ford Specialist 487 FE with a TKO600
Thought I would post this of the backend...
No. Description Supplement Qty From Up To Part Number Price Notes
01 REAR AXLE CARRIER 1 33311092625 $602.64
02 SET RUBBER MOUNTING D=60,5MM 1 33319059300 $46.04
03 SET RUBBER MOUNTING D=62,5MM 1 33319059301 $46.04
04 RUBBER MOUNTING 1 33171134910 $27.34
05 THREADED BOLT 2 33311136428 $6.25
06 COLLAR NUT M12X1,5 2 33311133463 $1.12
07 REDUCED-SHAFT BOLT M12X1,5X116-8.8 2 33321094476 $2.40
08 STOPPER 4 33331132546 $1.28
09 VIBRATION ABSORBER 1 33311090337 $79.52
09 VIBRATION ABSORBER 1 33316770851
10 COLLAR SCREW M12X1,5X65 1 06/1993 33321091100 $1.34
12 FLAT WASHER D=40MM 1 26111226237 $2.05
17 HEX BOLT WITH WASHER M12X1,5X80 ZNS 1 33176750780 $1.58
Here is the website I found this information on...http://www.realoem.com/bmw/showparts...66&hg=33&fg=30
The number 17 bolt is the one that sheared.
