Old 04-01-2007, 07:40 PM
Sydney Sydney is offline
Cobra Make, Engine: Shell Valley, 351W
Hi Greg. For the steering, I finally ended up with all Flaming River stuff. I used the fr1999ross30 column, and 3/4"-36 splined shafts and u joints. Also used the vibration resistant u joint at the column. It was pretty pricey, but well worth it for me. A couple of added bonuses is that the column worked very well with the Painless wiring harness that I used. And I have a functional horn button on the steering wheel.
For the pedals, I just used the SVC assembly for the brakes with Wilwood master cylinders. I did have to lenthen the pedal arm about 2" because I have the dropped footbox. It worked out good because it increased the leverage a little bit. After lots of trial and error, I ended up making my own floor mounted gas pedal assemby because it was just more comfortable for me for long drives.
Sydney
