Old 04-02-2007, 02:36 PM
1bad66's Avatar
1bad66 1bad66 is offline
Cobra Make, Engine: Streetbeast, 351W
Well one way to do it is while it is running, spray some carb cleaner around the gasket areas and if the rpm's jump up then you have a leak at the gasket. If it is a new engine, I would check the torque on manifold bolts, sometimes they come loose.
