Old 04-03-2007, 06:59 AM
strictlypersonl strictlypersonl is offline
What is your current ignition setup? If you are using an MSD with a tach output you can probably continue to use the MSD tach output. If you are using a system without a dedicated tach output, connect the white wire to the signal terminal on the tach.
