Thread: Breakdowns
Old 04-05-2007, 06:25 PM
Wazza's Avatar
Wazza Wazza is offline
Originally Posted by dbn04
warren,
what stroker kit did you use? thinking of stroking myself (engine that is)
If it helps, I've attached the "blurb" Ii have on a poster thingy I use when I enter any show and shines etc.
It just lets people see what's in the engine without having to ask a lot of questions.
Anyway.....
OWNER : Warren and Joanne BOYLAN, Gold Coast, Queensland.
347 Windsor Stroker Engine,
Engine Built by A.P.E. Motorsport, (A.N.T. Mechanical) Gold Coast Ph. 55637755.
With 750 D.P. Barry Grant Carburetor , Power Plus Crossflow Air-Gap Intake Manifold, EDELBROCK PERFORMER R.P.M. Alloy Heads, (Port matched 2.02 / 1.6) , H.O. Mustang Block, with mainbolt girdle , Forged Steel SCAT Crank , CRANE Cam , Forged H Beam Conrods , ARIAS Forged Flat Top Pistons , Eaton Race Solid Lifters , Moly Hardened Push Rods ,Platinum YELLA TERRA Shaft Rollers, 1.7 Ratio Rockers , ICE Digital Electronic Distributor, and control box, 9mm. Race Leads, Iridium Spark Plugs, Custom Exhaust, 1 3/4 inch Headers, into 4 inch collector, and 2 1/2 inch system, H.P.C. Coated ,Ford Racing Chrome Alloy Tappet Covers, Hi-Energy 6qt. Baffled sump, Hi-Volume Oil Pump, External Cam Belt Drive System, CVR High Performance Electric water pump, Romac Alloy Harmonic Balancer , ROIL Metal treatment,,
Clutch: Heavy Duty EXTREME ,10 Puc Cerra-mettalic.
Gear Box: TREMEC , TR3550, with B.&M. Short Shifter.
Diff: Borg Warner 3.7 With KAAZ 24 Clutch Plate L.S.D.
Brakes: VL Commodore, with braided steel lines, and Race Pads.
Wheels/Tyres: ROH 3 piece, 245/45/16 FALKEN Sports.
Suspension : King Springs, KONI Adjustable Shocks.
360 R.W.H.P.
400 Metres : 11.9 Secs. / 119.8 m.p.h. (13/07/06)
