Thread: Steering Shaft
Old 04-07-2007, 06:08 AM
Automan Automan is offline
Hey guys. I found out what the problem was. The bracket that mounts on the side of the footbox which mounts the steering column in the engine compartment using a C-clamp was on wrong. The C clamp base isn't even, Its offset. So when i turned it around, it pulled the column by almost half an inch away from the exhaust flange where the header mounts. Lots of room now. Now continue with my wiring.
Thanks for the help
Automan
