Thread: Steering Shaft
Old 04-08-2007, 10:36 AM
TonyMadrid's Avatar
TonyMadrid TonyMadrid is offline
Cobra Make, Engine: A&C 351W, C4
Default Column Clamp
If you're using the U-bolt clamp to mount the column to the foot box, don't over-tighten the clamp. If you do the column will squeeze and the shaft will not spin freely.
When I did mine, I thought the problem was heat from the headers causing the bushing to expand so I made a heat shield but it didn't help.
I called IDIDIT and they sent me a bushing with a few thousandths of an inch more clearance but that also didn't solve the problem. I then tried loosening the clamp and that was the cure.
