Old 04-09-2007, 09:56 PM
round_midnight round_midnight is offline
Cobra Make, Engine: BDR 187 Prism Red w/Silver stripes; 427 stroker by Smeding Performance, Tremec TKO600 gearbox
New head bolts were used and torqued to the builder's specs (with a torque wrench). I used moly lube on the threads and tightened them in three stages: 85 ft-lb, 95 ft-lb, and then 105 ft-lb. I tightened them in a pattern from the center to the ends.
I don't know how long the problem has been going on, but probably for a few hundred miles. It has gotten pretty hot (220-230 deg. F) on a couple of occasions when I didn't realize the coolant was low. I'm thinking those occasions were after the gasket started leaking and probably just made it worse, but I can't be sure.
'round Midnight
You'll feel me coming
A new vibration
From afar you'll see me
I'm a sensation!
-Pete Townshend, Tommy
