Old 04-10-2007, 05:25 AM
Philm's Avatar
Philm Philm is offline
Default Pics
As you can see we are going away with the car so it has to be in peices the week before.
The pics below whow the roll bar but I have half pulled it out to get the diff out, it comes out by dropping the front first
The bar is only light but settles the car nicely, the rear tended to wobble or waddle like a duck the bar helps this.
In this pick you can see the tab with the 2 holes, that is where it is mounted, I would weld those tabs on the other side if the tube. I made a plate that allows the mounts to be in the correct postion.
I will post some more pics when I put it back together.
Peter, dont worry about giving away secrets, when they run chevy power they need all the help they can get.
Phil
