Old 04-14-2007, 01:16 PM
jerry w's Avatar
jerry w jerry w is offline
Cobra Make, Engine: Antique & Collectable 302, C-4,Ford 9 inch
Your gauge should come with wiring instructions.
One way:
Run the positive connection into "gauge" connection of your wiring harness. All your other gauges go back to a fused connection on the wiring harness.
Ground the Voltmeter, there should be a "ground" near where all your other gauges are grounded.
Finally there should be a wire for the light bulb on the ampmeter gauge, connect it to the Voltmeter light bulb.
Hope this helps.
Regards
Jerry
