Old 04-14-2007, 03:17 PM
Yetiman's Avatar
Yetiman Yetiman is offline
Cobra Make, Engine: Arntz/SBC/Jag
Originally Posted by cobrashoch
Going the other way (positive) requires a much higher rated switch, because everything is running through it in load condition.
You require a high current rated switch either way. The negative lead flows just as much current as the positive lead. It is a complete circuit. Put a 100 amp fuse in line on the negative lead and see if you can start your car on a cold day without blowing the fuse.
If all cars had a positive ground system, it wouldn't have even been such a bad idea. The biggest problems arose because it didn't catch on.
We come into this world naked, screaming, and covered in blood. With dedication and a little planning, you can go out the same way.
View my overflow Gallery (much more to come !)
