Old 04-14-2007, 03:54 PM
Roscoe's Avatar
Roscoe Roscoe is offline
After masking with tape I used what is known as a Forstner bit. Makes a nice clean hole. I started it straight in and, once it bit in, I moved the bit so I could drill the oval. I finished it with a dremel. Make sure you use silicone when you put the rubber things in. Makes them go in real easy.
Roscoe
Roscoe
