Old 04-15-2007, 10:03 PM
Philm's Avatar
Philm Philm is offline
Default Suspension settings
Hi Andrew,
I just had the cobra wheel aligned and this is what we ended up with.
Front,
Camber -2'06 -2'13
Castor -5'08 -5'11
Total Toe 2.00out
Rear
Camber -1'56 -1.57
Toe 1.00 out 1.00 out
As plums said tyres are the usual stumbling block, also check out side diameter, if you can the clostest you can get to 680mm outside diameter the better the look, also that is the dimension of 295 50 15s.
Phil
