Old 04-16-2007, 08:37 AM
patrickt patrickt is offline
Originally Posted by strictlypersonl
Assuming the car is on a level surface, just fill to the bottom of the hole. Much more and you might see the excess oil on the floor eventually.
Thanks. That "other" car company (which was my runner-up to an ERA) had the following bold warning:
Warning: The differential covers that we use locate the drain plug approximately an inch higher than the original covers. (Original style covers are no longer available.) Do not fill the differential to the drain plug or it will cause heat and high pressure in the diff and blow out the seals.
