Old 04-18-2007, 04:13 AM
Anthony Anthony is offline
Cobra Make, Engine: CSX4000, 427
Originally Posted by 82ACAUTOCRAFT
I would like feedback from people using the new aluminum blocks, problems, durability issues, stretching, leaks overheating, etc.
For example aluminum rover V8 have a problem with sleeves moving down the block and coolant entering the combustion chamber.
Except for your thread above, no one has come up with valid reasons why I should use an aluminum block! My car is original and it is currently fitted with a 428!
The aluminum block is lighter (obviously), and can be repaired much more easily than an iron block if your engine builder screws up. Ask me how I know.
In your case, I'd keep the original 428 block, same one they put in the galaxies.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
