Old 04-18-2007, 06:52 PM
jarendall jarendall is offline
Cobra Make, Engine: StreetBeast 66 replica 302 350HP
the GM calipers are notorious for the piston sticking, you may have to change out the O ring on the piston, to find out if the piston is stuck jack the front up and try rotating the wheels, they should turn with just a little or no resistance, some calipers use a ceramic piston, if you have these, throw them in the trash and get a set of stainless steel ones, if the problem isn't in the front brakes, you can jack up the rear, with the transmission in neutral rotate the tries to see if they will turn, if not remove the rear drums and try rotating the axle, this will tell you if the problem is in the rear brakes or the drive train, if the drums are hard to get off, then the brakes maybe to tight, once you get the drums off you can loosen up on the self adjuster
PS: since you have already changed the front calipers, I doubt that the problem is there, I also have the Shell Valley pedals and duel masters, I changed them out to Wilwood's with remote reservoirs, the pedal must be set so that their is a little slack when the pedal is completely released, if not the fluid to the calipers and wheel cylinders will not return
PapaJohn
