Old 04-19-2007, 05:40 AM
JBo JBo is offline
Cobra Make, Engine: Ex CSX3327, & AK7113 AutoKraft AC MK IV
Originally Posted by Bill Wells
JBo ...satrday
The 3 SPF STREET version undercar rear exit exhaust cars i have seen have a very well done factory installed heat resistant insulated undercarriage due to the exhausts running under the car. The sound is different, the look cleaner . Those cars have a nice sound to it at wide open throttle take offs and a nice rumble at idle , quieter at highway speeds vs side exhaust counterparts . I assume the insulation from the factory is still part of the undercar exhaust choice .
The street cars can also be ordered thru SPF dealers without hood scoops or without roll bars if ya want an ALL original street version car look ....also , the hood if scoop is on it may not have the rivets with the scoop blended into the hood at its edges vs looking 'stuck on' with rivets like the S/C car versions . Scoops can be ordered either way .
It looks good, sounds good , is well insulated by the factory underneath. If that is what ya want , go4it . Bill
Bill, that is the set up all AutoKraft AC's MKIV's (non lightweights) came with from factory, except silencers/mufflers were in rear wheel wells. Rear tread is about 4inches wider than a MKIII via Frua uprights, bearings and compomotives 15's or 16's with a bit moire backspace. They did this as the cars were equipped with cats and passed epa regs. Jim
