Old 04-20-2007, 08:57 AM
bobcowan's Avatar
bobcowan bobcowan is offline
If you just want to remove the cover, no need to pull the axles out.
Getting it back on can be a bear. You don't want it sliding around and making a mess with the silicone sealant. Get a couple of 1" 5/16 bolts and cut the heads off. Cut a screwdriver slot on the end. You can use them as alignment studs for the cover.
