Old 04-22-2007, 06:13 AM
macloft macloft is offline
My engineer tells me the pod filter is ok, I do need the MAF installed however (he somehow believes I also will remove it later).So I will mount the MAF straight onto the throttle body and using tubing like AUSSIE MIKE I will mount the pod filter (SS Inductions) somewhere in a ducted cold air stream. Most likely use the front side vents using a part similar to Finish line.
I will use Phil Neals suggestion for the idler pulley.
Thanks
